Activity Forums Blackmagic Design RT 3 Way Colour Corrector in HD
  • RT 3 Way Colour Corrector in HD
    Posted by Paul Ingvarsson on June 6, 2005 at 9:42 pm
    Excuse the maybe dense question but I don’t have the decklind card yet.
    I read in some of the BM tech info that the 3 way colour corrector works in full resolution in real time. Ie I can output to tape without rendering.
    Is this possible with HD (lets say uncompressed 10 bit 4:2:2 – 1080p 25fps)?
    Also should I expect any effects to be real time when working in HD??
    Paul
    Jeff Bernstein replied 21 years, 3 months ago 5 Members · 9 Replies
  • 9 Replies
  • David Battistella
    June 7, 2005 at 4:20 am
    The card has nothing to do with this. It all depends on your drive speed, computer and RAM.
    David
  • Kaspar Kallas
    June 7, 2005 at 12:53 pm
    Actually NO
    the color corrector is built into the card and yes you can make realtime CC on they fly even in HD with the exception on 4:4:4 RGB format
    -Kaspar
  • Paul Ingvarsson
    June 7, 2005 at 1:05 pm
    thanks for this info! I thought the card was doing som ework….
    Is there a list of what RT effects can be used in full resolution in HD on the card??
    Paul
  • David Battistella
    June 7, 2005 at 2:36 pm
    Kaspar,
    Is there daughtercard processing on this card? Can you select the Declink HD to do the FX from within the final Cut Ro effects handling pane? I just don’t see where the cards “extra” processing power is coming from.
    David
  • Kaspar Kallas
    June 7, 2005 at 4:01 pm
    I am sorry
    I havent cheked how things are done in FCP 5 but int FCP 4.5 yes you could choose blackmagic for effect handeling and yes there are hardware aplications on the card for CC tools
    I dont know how the things work under the hood – what I do know is that I have set the effect handeling to FCP all other than BMD 8 bit 2Vuy codec and when I remove the card – no longer are CC tools realtime – not to mention any HD monitoring
    I heard the monitoring is now OK on cinemadisplay so only thing we need is someone without the hardware to try uncompressed 8 or 10 bit 1080i/p CC tools and we should have an answer?
    -Kaspar
  • Kaspar Kallas
    June 7, 2005 at 4:02 pm
    I am sorry
    -Kaspar
  • Bob Cole
    June 7, 2005 at 4:25 pm
    [David Battistella] “I just don’t see where the cards “extra” processing power is coming from.”
    Now I am really confused. I posted in an earlier thread a question about the diff. regarding RT effects, bet. the HD 4:2:2 (which also handles SD) and the forthcoming Matrox Axio.
    The answer was, the Blackmagic card is strictly i/o, all processing for RT effects (dissolves, etc.) is on the CPU.
    This thread seems to suggest otherwise…? Or am I reading too much into it?
    — BC
  • Jeff Bernstein
    June 8, 2005 at 8:11 am
    Actually, the effects are done on the CPU through the Blackmagic driver. Thus, RT Extreme or Blackmagic can be selected as the FX architecture.
    On the Decklink HD Pro, however, downconversion is actually done in hardware on the card. I would imagine that upconversion would work the same way one day.
    On the Decklink HD, downconversion is performed by the Blackmagic driver on the CPU.
    I hope that clears it up.
    Jeff Bernstein
    Digital Desktop Consulting
    Apple Pro Video VAR
    XSAN Certified
    323-653-7611
  • Jeff Bernstein
    June 8, 2005 at 8:30 am
    The main question to ask Apple is “Which built-in FX are 8-bit and which are 10-bit?” I’m dying to know.
    Keep in mind that AE Compatible Plug-ins in FCP can only work in 8-Bit RGB. The spec does not allow for YUV processing. It also allows for 16-Bit RGB processing, but FCP doesn’t go beyond 8-Bit RGB.
    Thus, I think the future could be found in Motion’s FX plug-in architecture called ‘FxPlug’ that can also enable real time processing. Time will tell.
    Jeff Bernstein
    Apple Pro Video VAR
    XSAN Certified
    323-653-7611
