Activity › Forums › RE:Vision Effects › RSMB vs RSMB Pro defaults
Posted by Navarro Parker on August 13, 2008 at 8:44 pmI notice they both are floating color capable. Is Pro any better looking or faster than the regular version at the default settings?
Peter Litwinowicz replied 10 years, 10 months ago 3 Members · 3 Replies -
Peter Litwinowicz
August 14, 2008 at 1:21 amAt the basest level (if you are not using the plugin which uses vectors from a 3D system), the two plugins are the same.
The PRO version adds more features, but is not faster or better at the default settings. You can read about the differences here: https://www.revisionfx.com/products/rsmb/features/#After%20Effects,%20Premiere%20Pro,%20Final%20Cut%20Pro,%20Commotion,%20Combustion,%20and%20Boris%20Red
Cheers,
Pete Litwinowicz -
Peter Litwinowicz
October 29, 2015 at 3:44 pmNew link: https://www.revisionfx.com/products/rsmb/features/#ae_compatible_5
Note that the Pro section is what’s added in the Pro version.
pete
