Activity › Forums › RE:Vision Effects › RSMB Pro Vectors After Effects – workflow for C4D/Redshift (help!)
  • RSMB Pro Vectors After Effects – workflow for C4D/Redshift (help!)
    Posted by Liam Pope on October 11, 2020 at 9:46 am
    Hi all. I’m hoping someone can shed some light on the correct workflow for RSMB Pro vectors with motion vector passes from C4D physical/redshift. I am using S22 with Redshift 3.0.27 & RSMB Pro 6.2.
    I seem to be following the same workflow as seen in online documentation, but my results are always the same; RSMB blurs the entire scene, regardless of the vector data I give it.
    Another post suggested that this issue may be unique to C4d versions past R20, could anyone confirm this?
    Attached is a snapshot of the issue I am facing. Note how the whole scene is blurred despite the MV pass only containing my subjects.
    Some info:
    – MV passes rendered as 32bit EXRS, both as seperate EXRS and combined with the beauty pass
    – Tried with a transparent alpha for the MV, as well as a matted black background\
    Going a little crazy with this one. Any help is greatly appreciated.
    Liam Pope replied 5 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
