Activity › Forums › Adobe After Effects › RSMB on film-like motion blur
  • RSMB on film-like motion blur
    Posted by John Estar on April 15, 2008 at 12:17 pm
    Hi all! Im new here, from Argentina.
    My question:
    How is the equivalent setting in ReelSmart Motion Blur, pro or lite, or maybe Twixtor to the equivalent sensitivity of motion in film (180º 1/48 shutter speed)?
    Im dealing with a deinterlaced source converted from 60i to 23.975 and is juddgering. My idea is to add some motion blur to eliminate this and conform more confortable 24p experience. For this i think to match the 1/48 shutter blur…
    thx in advance and sorry for my english!
    Chris Wright replied 18 years ago 3 Members · 2 Replies
  • Pierre Jasmin
    April 17, 2008 at 1:58 am
    If this helps .5 is like 180 deg shutter
    If you are going from 60 to 24, it would depend if you apply the MB before subsampling time (while still 60) or after.
    comp1 setting: 59.94
    apply MB using a large value like 0.5 (it’s in part arbitrary as there is already some MB in the image if things move fast).
    0.5 at 59.94 should produce about the same blur length as .2 (.4 (23.976/59.94) x .5 (amount value)) at 23.976
    comp2 setting: 23.976 FPS
    drop comp1 and comp2
    Pierre
  • Chris Wright
    September 8, 2008 at 5:34 am
    I used to have this same problem. I would have judder and think that just adding more motion blur would make it a whole lot better. I found that if you use twixtor’s frame rate and its speed change together, it will sub-sample more in-between frames for you. I used 98.75 here but 80% really helps a lot more.
    https://forums.creativecow.net/thread/50/855707#855715
