Activity Forums RE:Vision Effects RSMB on black text
  • RSMB on black text
    Posted by Roger Averdahl on March 26, 2006 at 4:49 pm
    Hi!
    RSMB do not blur black text. I have to make the text white, add RSMB and then add Tint to map white back to black. This workaround works, but is there a way to blur black text with RSMB without this workaround?
    I am using AE 7.0.
    /Roger
    Roger Averdahl replied 20 years, 5 months ago 2 Members · 3 Replies
  • Pierre Jasmin
    March 27, 2006 at 7:28 pm
    In practice what happens internally is that on a setup as you describe you end up with black text on black which RSMB cannot deal with.
    To sandwich it like this:
    Invert Green
    RSMB
    Invert Green
    would work
    Also, for your information, with flat (no texture) large text, it might work better if the text motion is the same for all characters to use RSMB PRO without image tracking and use the Tracking Points in RSMB PRO to indicate the motion OR simply use SmoothKit Frame Accumulate then RSMB if the each character is animated separately.
    Pierre
    RE:Vision Effects
  • Pierre Jasmin
    March 28, 2006 at 4:52 am
    “OR simply use SmoothKit Frame Accumulate then RSMB if the each character is animated separately”
    should have been
    OR simply use SmoothKit Frame Accumulate RATHER …
    Pierre
  • Roger Averdahl
    March 28, 2006 at 8:31 am
    Thanks for the help Pierre! 🙂
    Invert+RSMB+Invert was much better than my workaround. I will look into the other things you mentioned.
    /Roger
