Activity Forums Adobe After Effects Rsmb issue !
  • Graham Quince
    September 18, 2021 at 11:13 am
    I’ve not used RSMB, have you contacted Revision FX for support?
  • Pierre Jasmin
    September 23, 2021 at 10:12 pm
    <div>
    </div>
    It should, as suggested maybe send a project to techsupport@revisionfx.com
    The only known issue is if you use some transform effect before on layer that changes the size of frame at each frame, then you likely need to pre-comp and apply RSMB in parent comp.
    Pierre
