Activity Forums RE:Vision Effects RSMB and combustion (windows) bug …
  • RSMB and combustion (windows) bug …
    Posted by Dan Rapaport on September 4, 2008 at 9:53 pm
    Hello
    I have a bug (annoying ;)). In combustion, when using rsmb, but not all the time and didn’t find yet when exactly, all objects in my timeline disappears. For example, when you nest and then add a rsmb, usually, you loose the object names in the timeline, it’s like an empty timeline.
    To correct the problem, you can delete the rsmb (disabling it changes nothing) or you select an object higher in the hierarchy in order to get back the objects in timeline. But if you go back to your normal level (like working in the nest), you loose again the objects.
    Not sure I’m clear.
    Are you aware of this problem? Is there a fix?
    Thx
    Peter Litwinowicz replied 18 years ago 2 Members · 1 Reply
  • Peter Litwinowicz
    September 4, 2008 at 11:52 pm
    Never have had this reported, but I believe you 😉
    What version of RSMB and what version of combustion are you using?
    Can you send us a project, and some source footage, and tell us what to do to see the bug?
    Pete
    https://www.revisionfx.com
