Activity › Forums › Adobe After Effects › RSM not working right in Nuke
  • RSM not working right in Nuke
    Posted by Claudio Pavan on January 23, 2009 at 12:52 pm
    Hi I just purchased real smart motion blur for nuke on my windows 64 bit machine.
    Im rendering out rasterize motion vectors from xsi7 64 bit.
    When I comp the frames in nuke and apply the realsmart plug-in node the result i get is not right, I have tested the same frames on a After effects comp and the result in after effects seems accurate. I really need this to work in Nuke.
    Any suggestions?
    Pierre Jasmin replied 17 years, 8 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    January 23, 2009 at 4:49 pm
    I bet you have the make sure the Motion Vectors Input is set to raw (check the raw data button for that read node) otherwise it gets linearized while it already is.
    Pierre
