Activity Forums Adobe Premiere Pro RS422 plugin
  • RS422 plugin
    Posted by Allby Corry on November 6, 2010 at 3:01 pm
    Does anybody know why Adobe left out of Premiere CS5 the serial RS-422 controller plugin.
    I have a USB-Serial adapter with a 9pin-422 cable but can not control a UVW1800 without this plugin.
    Regards,
    Allby
    Allby Corry replied 15 years, 10 months ago 2 Members · 2 Replies
  • Tim Kolb
    November 7, 2010 at 8:57 am
    “Left out”?
    Not sure what you mean by this… Analog deck control is usually handled by the card you install in your machine that handles analog video/audio connections.
    Deck “control” without a deck “connection” of some sort isn’t a common need, and therefore this is handled by the I/O card manufacturer (AJA, Blackmagic Design, BlueFish444, Matrox, etc…)
    TimK,
    Director, Consultant
    Kolb Productions,
  • Allby Corry
    November 8, 2010 at 4:27 pm
    Thank you Tim,
    But I am using a Matrox MXO2 Mini that have no connection RS:422.
    I remember that in CS3 or CS4 had an option to capture using a serial option “serial 422 UVW” but it disappeared in the CS5.
    I have a Addenda USB-Serial adapter and a 9pin-422 cable that I tested with the program OCX422 and the UVW1800 and work.
    Regards,
    Allby
