Activity Forums Apple Final Cut Pro Legacy RS422 HQ vs. Uncompressed
  • RS422 HQ vs. Uncompressed
    Posted by John Dehn on December 16, 2008 at 4:58 pm
    Hi.
    I’m going to be editing a standard definition documentary project that was shot in Beta SP. (Remember those really big tapes?) I’m considering using the RS 422 HQ codec instead of the Uncompressed 8-bit codec. To my eye, I can’t really see the difference. I’d love to hear what other people think of that plan.
    I’ve got a 2.3 ghz Dual Processor G5 with a Blackmagic Extreme HD card.
    John Dehn
    Eric Sternberger replied 17 years, 9 months ago 6 Members · 6 Replies
  • Jerry Hofmann
    December 16, 2008 at 5:25 pm
    It’s a great plan. ProRes will be smaller, render faster, is more friendly with RT Extreme, and looks the same… Can’t see a downside myself.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Sean Oneil
    December 16, 2008 at 5:31 pm
    ProRes compression is similar to the compression found on Digibeta tapes (something I never hear people worry about). So yes, it’s totally fine.
    Sean
  • Steven Gonzales
    December 16, 2008 at 6:14 pm
    RS 422 is a serial communications protocol.
    Perhaps you mean ProRes 422 codec?
  • John Dehn
    December 16, 2008 at 6:19 pm
    Yes, I meant Pro Res. Sorry about that.
  • Rafael Amador
    December 17, 2008 at 2:09 am
    Agree. Is the best choice.
    Rafael
    http://www.nagavideo.com
  • Eric Sternberger
    December 17, 2008 at 12:09 pm
    …good choice, but no need to go HQ for SD-resolution, SQ will do also for SD-work.
    We switched a couple of weeks ago completly to ProRes for SD-editing. Since then we edited 4 TV-Shows shot on digi-beta with ProRes SQ settings.
    No one can tell the differnce between 8-bit uncompressed SD and ProRes.
    But you have the advantage of 4 times less space+bandwith needed on your raids.
    therefore editing in ProRes feels much more speedy, even on a G5.
    The 10bit codec gives you even a better picture quality, especially if you do a lot of effects & grafics.
