Activity › Forums › AJA Video Systems › RS422 control of Sony HDV VTR.
  • RS422 control of Sony HDV VTR.
    Posted by Bob Zelin on September 3, 2005 at 7:08 pm
    Just for the record, I have now used the Addenda RS-4/L to give RS422 control to the Sony HDV VTR (which uses LANC, not RS422). The Addenda
    plugs in between the AJA product and the Sony HDV VTR. There is no software to install – it just works. And it’s only $148.
    Bob Zelin
    Brian Conner replied 20 years, 9 months ago 5 Members · 26 Replies
  • 26 Replies
  • David Battistella
    September 4, 2005 at 3:24 am
    Bob,
    FYI. I just did some tests with the SONY HDV deck using the firewire as the deck control and it recaptures frame accurately. I hope to have an article out about these tests soon.
    David
  • Brian Conner
    October 12, 2005 at 2:45 am
    This might be more or less a dupe reply. The first time, it didn’t seem to post.
    I’m trying to set up a new HDV/Kona2 FCP system right now, and I can’t seem to get firewire deck control to work.
    Sony HD-M10U
    Aja H10U
    Kona 2
    Huge 4210
    ATTO FC-42XS
    PM dual 2.7 G5
    FCP 5.0.2
    OS v10.4.2
    Video from the HDV deck shows up in Log & Capture fine (Kona2 1080i uncompressed 8 bit), but I get the “unable to initialize deck” warning when opening Log & Capture.
    When I change to HDV Easy Setup, there is no problem with either deck control or video, through the same FW cable (Granite Digital cable).
    Any ideas?
    Brian Conner
  • Gary Adcock
    October 12, 2005 at 3:00 am
    Brian
    you need to manually set the deck control to DV and make a new easy setup.
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL USA
  • Brian Conner
    October 12, 2005 at 3:14 am
    Yes, I’ve done that, Gary. In desperation, I’ve tried all the firewire Deck Control presets, anything that says firewire, I’ve tried it (even though I knew they wouldn’t work, I tried anyway; we’re talking desperation.)
    And I’ve done the usual power-cycling of all devices, and a complete Shut Down, to try to reset things. Still no joy.
    It’s not making sense. Tomorrow I’ll trash prefs and start over. Going to bed – early appointment in the morning.
    Brian Conner
  • Brian Conner
    October 12, 2005 at 6:08 pm
    No go. I’ve tried everything I know to do.
    Anybody have any suggestions, before I pay the $148 for the Addenda LANC/RS422 adapter?
    Brian Conner
  • David Battistella
    October 12, 2005 at 6:13 pm
    Brian,
    I did this successfully recently and reported in in an upcoming article here on the cow.
    I am fairly sure that I used the NTSC firewire for deck control and whatever capture preset you need to capture.
    David
  • Walter Biscardi
    October 12, 2005 at 6:16 pm
    [Brian Conner] “Yes, I’ve done that, Gary. In desperation, I’ve tried all the firewire Deck Control presets, anything that says firewire, I’ve tried it (even though I knew they wouldn’t work, I tried anyway; we’re talking desperation.)”
    Are you changing all the settings on FCP or on the Deck? Is there anything on the deck that needs to be changed to allow Firewire control? I don’t have one so I don’t know, just throwing that out there.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
  • David Battistella
    October 12, 2005 at 6:22 pm
    Walter,
    I was just changing the FCP settings. This way FCP thinks it is looking at a firewire deck, but you can be sending component HD via whatever codec you want in FCP. The HDV deck has no RS-422. The upcoming article might debunk a myth or two.
    David
  • Brian Conner
    Thank you for the reply, David. It’s strange that FW deck control works fine when the capture preset is HDV, but not when it’s Kona2 1080i 8 bit.
    This is the first FCP hi-def system I’ve built. I’ve got a lot of SD systems out there running well, but this is the first client who needed hi-def. So, I’m feeling my way along the walls.
    If I cam’t find the secret soon, I’ll pull out the Visa Card and call Bruce at Addenda.
    Brian Conner
  • Walter Biscardi
    October 12, 2005 at 6:26 pm
    [David Battistella] “The upcoming article might debunk a myth or two.”
    I’ll be realy interested to see what you think of the quality. I have seen absolutely no HDV footage that makes me want to jump out and embrace the format. I’ll take DVCPro HD any day over HDV.
Page 1 of 3
