Activity Forums AJA Video Systems RS232 to RS422 conversion
  • RS232 to RS422 conversion
    Posted by Jason on May 1, 2006 at 1:25 am
    I have an AJA ioLA connected to a Sony DSR20 DVCAM deck (s-video) and a Sony UVW1800 BetaSP deck (component). I’m using the RS422 control from the AJA to control the Beta deck, but the DSR20 has RS232, so I’ve tried using firewire to control the DSR20, but the firewire connection for the AJA seems to be conflicting with the firewire I
    Jason replied 20 years, 4 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    May 1, 2006 at 11:04 am
    What you need to do is get a keyspan rs-232 to USB adapter. Then you should set up a different easy set up with a device control preset for each deck. This makes it easy to a/b between the decks with no patch cables or patch panels and avoids an a/b box.
    https://www.keyspan.com/products/usb/USA19HS/
  • Jason
    May 1, 2006 at 1:57 pm
    So I hook up the Keyspan and FCP will automatically add USB/RS232 as an option for device control under A/V settings?
  • Jeremy Garchow
    May 1, 2006 at 2:52 pm
    Well, not really automatically. You need to install some drivers, and then go into the a/v settings and under device control you will see keyspan serial or something like that. It’ll be obvious once it’s installed.
    Jeremy
  • Jason
    May 1, 2006 at 3:13 pm
    Okay, thanks.
