Activity Forums AJA Video Systems RS-422 Switcher for FCP System???
  • RS-422 Switcher for FCP System???
    Posted by Michael Cavallaro on February 1, 2006 at 7:35 pm
    I am trying to set up multiple decks with my AJA Io and I need to find a switcher for the RS422 Remote cable but I can’t seem to find one that isn’t overkill.
    Is there a 3 port switcher out there somewhere? I don’t need a 16 port rack mount switcher.
    Thanks…MikeC
    Deepblue7600 replied 20 years, 7 months ago 3 Members · 6 Replies
  • Bob Zelin
    February 1, 2006 at 11:59 pm
    go to google, enter ABCD 9 pin switcher – in those exact words, and you will see dozens of mail order companies selling 9 pin switchers for your application. A 4 port ABCD 9 pin switcher is a very common product. BUT, I still think you wuold be better off with the 16 port (or 12 port) patch panel.
    Bob Zelin
  • Michael Cavallaro
    February 2, 2006 at 12:03 am
    Oh great…I was searching for RS422 Switcher and I wasn’t getting much.
  • Michael Cavallaro
    February 2, 2006 at 12:05 am
    These are serials switchers right? Don’t I need RS422? Or does RS422 work with the serial switchers?
  • Bob Zelin
    February 2, 2006 at 2:14 am
    you are simply switching all 9 pins of a db9 connector. There is no difference between a serial port (or comm port) switcher, and a RS422 switcher. They use pin to pin cabling, with no cross connectors. There is no such thing as an RS422 switcher (unless there is a marketing strategy from companies that make video routing switchers that include RS422 switching, and this is just pin to pin switching). So yes,these cheap $15 boxes will work just fine.
    But like I said, if it were me, I would buy a patch panel.
    bob Zelin
  • Michael Cavallaro
    February 2, 2006 at 4:20 am
    Great! I was thinking that this was going to be an expensive solution 🙂
    Thanks so much for the info!
    MikeC
  • Deepblue7600
    February 15, 2006 at 9:23 pm
    Ok, I’ll bite. Why would you recommend a patch panel, and which one?
    Eric
