Activity Forums Blackmagic Design rs-422 not giving timecode
  • rs-422 not giving timecode
    Posted by Eyad Hamam on September 6, 2006 at 10:15 pm
    Hello,
    I tried capturing some digi-beta material from sony’s dvw-250 portable deck, and while I can see the video and hear the audio coming in throgh the SDI,I’m not getting any timecode or deck control inside FCP 5 (powermac 2.3).
    When I use BMD’s deck control utility, I can control the deck but I don’t get timecode, and I can’t capture video.
    I tried changing the settings on the deck from VITC to LTC, and I tried playing with the setting is FCP, but I’m not getting anywhere.
    Does anyone have an idea of what might be going on?
    thanx
    Eyad Hamam replied 20 years ago 2 Members · 4 Replies
  • Eyad Hamam
    September 7, 2006 at 12:43 am
    ps… i’m using a decklink extreme pci-e…
    🙂 sorry, forgot the most important part.
  • Eyad Hamam
    September 9, 2006 at 11:58 pm
    i guess there isn’t a solution?? or noone has an idea of what’s going on and how i can fix it…. please help. what’s the point of a capture card that doesn’t control the deck!
  • Kristian Lam
    September 10, 2006 at 11:25 am
    According to the DVW-250 manual, the serial control port is switchable between Sony 9-pin protocol and RS232. Unfortunately, it does not specify how this is configured. Could this be the reason you’re having trouble? Is there a way to confirm that the deck is indeed switched to using Sony’s 9-pin protocol for its remote control port?
    regards
    Kristian Lam
    Blackmagic Design
  • Eyad Hamam
    September 10, 2006 at 12:06 pm
    Hi Kristian,
    Thanx for the tip. I will check when I have access to the deck again. Is there any kind of test I can run without having an actual deck connected to make sure that the problem isn’t from the card or the cables?
    thanx
    eyad
