Activity Forums Apple Final Cut Pro Legacy RS-422 = DB9?
  • Posted by Steve Cohen on August 30, 2006 at 8:30 pm
    I’m looking for a manual switch box to allow me to control 2 decks from my Aja. I currently have a One-2-Pucnh, but it seems to have died. I get not communication in FCP, but when the decks are connected directly it works fine.
    Anyway back on the subject. I’m looking for a short term, inexpensive fix, because we are going to be installing a router in the next week or so.
    I can’t seem to find this listed on the web, and I think it also goes by DB9 (mainly for PC’s). Am I correct or thinking of something else.
    Or if you can point me point me in the direction of what I’m looking for that would be great.
    Steve Cohen
    Editor
    O2 Media Inc.
    Mark Raudonis replied 20 years ago 6 Members · 6 Replies
  • Aaron Neitz
    August 30, 2006 at 8:58 pm
    yeah,422 uses a DB9 connector. should work fine I’d think.
  • Jeremy Garchow
    August 30, 2006 at 9:29 pm
    It works fine, the only problem you might find is that the screws won’t quite screw in as the holes are metric and the pins are US, but it also migth not be a problem. A cheap DB-9 cable will work just fine. I have a long one going form my Kona 2 to a series of decks and an io if I need. It has not failed me. Make sure your have the proper genders on both sides and if the cable doesn’t, get a gender changer.
    Jeremy
  • Mark Maness
    August 30, 2006 at 9:30 pm
    You can purchase an A-B serial port selector box from just about any “real” computer shop, not the retail giants. I’ve used one of these for many years without problems.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Steven Gonzales
    August 30, 2006 at 9:43 pm
    One more thing to remember is to have one “control cable” going from Kona to the switch box, and the cables going out of the switch box to the 2 decks should be “straight through” cables (same pin assignments at both ends). With serial, you’ve got to keep the transmit and receive wires going to the right places!
  • Steve Cohen
    August 31, 2006 at 12:42 am
    I have the cables already. I’m just replacing the switch box. So a DB-9 Serial A-B switch box should work?
    Steve Cohen
    Editor
    O2 Media Inc.
  • Mark Raudonis
    August 31, 2006 at 4:18 am
    Yep. That simple “A-B” box will work just fine. If needed, they even make “A-B-C-D” boxes so you can pick from one of four decks to control.
    We’ve got a bunch of them deployed throughout the building. I think they cost less than $20.00 bucks.
    Mark
