Activity Forums Adobe After Effects RPF import 32bit ?
  • RPF import 32bit ?
    Posted by Bernhard Rieder on May 20, 2009 at 10:29 pm
    Hello,
    I want to use the max built in motion blur effect. Additional to that, I want to save my renders a 32bit images.
    – I tried .exr and .hdr and get the message: nope… not built for that
    – I tried .rpf works, that format works but I can’t load into After Effects Pro CS3 which is my comping tool
    so what to do ?
    How can I use the max motion blur effects with 32bit and After Effects ?
    thx a lot for every littel help
    Simon Twine replied 17 years, 3 months ago 3 Members · 3 Replies
  • Chris Wright
    May 20, 2009 at 10:55 pm
    hdr compander in effects utility, set one above max motion at compress, duplicate it and place another below max motion at expand mode.
  • Bernhard Rieder
    May 21, 2009 at 12:24 am
    Hello Chris,
    really appreciate your reply.. but I can’t follow you.
    when I try to load the .rpf I already get an error.
    But anyways, I just click ok when the message pops up: unsuported bit depth.
    so what do you mean ?
    once loaded and on a layer, I can go to the Effects panel, and choose the Utility–> HDR Compander
    Once this is done, I only have the option:
    Compress Expand Dynamic Range
    but when I do this, I still get the error message, and my image appears still black.. nothing changed…
    so what do I have to do ?
    thx a lot,
    bernhard
  • Simon Twine
    May 22, 2009 at 5:50 am
    you’ll have to drop the RPF to 16-bit, thats the only way i’ve managed to import it successfully.
