Activity Forums Maxon Cinema 4D Roving key frames in Maxon?
  • Roving key frames in Maxon?
    Posted by Robyn Rhodes on August 15, 2011 at 10:08 pm
    Is there a way to “Rove” KF’s in C4D the way you can in AE?
    I’m only half the thing I say I am, the other half are me.
    Greg Burrus replied 15 years, 1 month ago 2 Members · 1 Reply
  • Greg Burrus
    August 16, 2011 at 11:05 am
    Not sure you can do the right click rove equivalent in c4d like you can in AE but you can do the quick version(holding alt key) equivalent. You just select the key frames you want to rove, then select the ends of the yellow selection bar that is above all your keyframes in line with the word Key Mode.
    hope that helps Greg
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
