Activity › Forums › DaVinci Resolve › roundtip from Windows Resolve back to FCP7 – codec to use
  • roundtip from Windows Resolve back to FCP7 – codec to use
    Posted by Ben Scott on May 31, 2012 at 5:38 pm
    Have spent this afternoon trying to figure out a codec for outputting fcp roundtrip
    We are working on a PC resolve
    From what I have seen it isnt possible to get a reliable Codec out from this resolve PC to a mac with FCP 7 and a kona card
    Have tried
    Uncompressed YUV 422 8bit
    Uncompressed YUV 422 10bit
    Uncompressed RGB 8bit
    Have tried with colour bars (ungraded) and I am outputting signal from FCP to tektronics scopes where I am seeing a slight shift in chroma but not the Luma
    As I have also got a red render bar I am thinking the codec outputting from the PC resolve isnt optimised for FCP e.g. its reading as Apple none (for the YUV outputs) or none (for RGB outputs)
    Is there a specific solution I should be using e.g. a good codec that isnt cineform
    would prefer replies from people that have experience on windows version of resolve as this is probably a quicktime issue on windows or a codec issue from resolve on windows
    needing to find a solution as have big job on next week
    thanks
    ben
    Ben Scott replied 14 years, 4 months ago 3 Members · 5 Replies
  • Joseph Owens
    May 31, 2012 at 7:47 pm
    [Ben Scott] “As I have also got a red render bar I am thinking the codec outputting from the PC resolve isnt optimised for FCP e.g. its reading as Apple none (for the YUV outputs) or none (for RGB outputs)”
    Your biggest single clue.
    When Apple sees “Uncompressed” as “None”, then its a Quicktime/file problem; cross-platform from PC/Windows/NTFS to Apple/OSX/MacOS. There are issues with byte-ordering that will cause Quicktime under Mac to fail to see what the codec is when it is transported through NTFS. (I’m assuming you’re exporting the graded footage either through a server or an NTFS external hard drive.)
    Its possible that a re-render, even cross-rendered back into Apple Uncompressed will cure the problem — however, there may also be scaling problems inherent in this export path (of the nature 0-1023 / 64-940). Its bad news all around.
    Your slight shift in chroma/not luma may be due to the Y’CbCr –> RGB —> Y’CbCr not being mathematically rigorous, and it cannot be, oweing to round-off errors. But you ARE going to change the values of most of the footage…. right? Otherwise, if you want EXACTLY back what you sent, then … why are you grading? ;-D
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Sascha Haber
    May 31, 2012 at 8:55 pm
    haha, good one…
    I just say, get out of codec world, try Glue tools.
    A slice of color…
    DaVinci 8.2.1 OSX 10.7.2
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    ICA Instructor
    https://www.icolorist.com/Sascha.html
  • Joseph Owens
    May 31, 2012 at 10:02 pm
    [Sascha Haber] “I just say, get out of codec world”
    If only…. Bob Zelin mentioned it during his streamed NAB interview, that the codec mess we’re in is descending into madness. Unfortunately every compression geek out there thinks that they have “the answer” and just push it in whether its a good idea or not, and certainly almost nothing that we’re working with today would likely stand up to a SMPTE standards committee agreeing on whether to give it an actual format designation, like the old days of, for example “C” format tape, or conforming to an RP approval.
    jPo
  • Ben Scott
    May 31, 2012 at 10:39 pm
    I have been outputting blackmagic 2vuy file from avid pc with rgb output values for a whil reliably to fcp7
    It reads as uncompressed not none codec
    Will try a mac formatted drive with paragon to see if this helps eg not ntfs
    We were writing to exfat drive
    Haven’t properly seen the scopes out from resolve for the imported prores file as signal did realise that output at inputted levels mattered as did legal levels as working rec709
    Not too sure the glue tools solution is a long term fix, how do the clients get back the fcp7 timeline with rec709 easy to use files
  • Ben Scott
    June 3, 2012 at 9:23 am
    see that cineform has a free codec for gopro cameras and that seems to encode out from resolve, for the encoding in fcp 7 timeline for dissolves I found the cheapest is neoscene which should be fine for many 2d applications
