Activity Forums Maxon Cinema 4D Rounded Text
  • Rounded Text
    Posted by Simon Edwards on February 25, 2011 at 3:08 pm
    Hi There,
    I have what I hope should be a relatively quick question but as is usually the case with anything 3D I’m sure it’s more complicated.
    I know the process of extruding text from a spline and then using fillet caps to get a rounded front and back edge. My question is how to I round the length edges, running between the front and back face? I tried making it all an editable object then connect and delete the layers but when I bevel the caps come away?
    I hope that’s a clear question, thanks for the help! #
    Simon
    Simon Edwards replied 15 years, 6 months ago 3 Members · 5 Replies
  • Adam Trachtenberg
    February 25, 2011 at 7:29 pm
    You need to round the spline that you’re extruding if I understand what you’re asking for.
  • Brian Jones
    February 25, 2011 at 8:10 pm
    Maybe a loftNurb using 3 copies of the text. Make the middle spline bigger – maybe the outer part of an Outline spline (but you’d likely have to reverse the sequence after outlining)
  • Simon Edwards
    February 25, 2011 at 8:11 pm
    ah I feared that may be the case and there wouldn’t be an easy fix. Thanks for clearing that up for me!
    Si
  • Simon Edwards
    February 28, 2011 at 12:43 pm
    oo That’s a good idea, I’m gonna have a play with that this evening! Cheers
  • Simon Edwards
    March 1, 2011 at 10:00 am
    I thought this might interest people,
    https://lesterbanks.com/2011/02/using-the-soft-body-tag-with-text-in-cinema-4d/
    After much faffing about and managing to get it to work I came across this tutorial which would have made thhings much more simple!
