Activity › Forums › Adobe After Effects › rounded rectangles
  • rounded rectangles
    Posted by Kevin Pedersen on August 12, 2011 at 8:03 pm
    hey all
    New to the forum so let me know of mistakes.
    Im working on a video project where i have to make a row of rectangles with rounded edges with gradient on the faces(sides). On the front of these rectangles there has to be video or images playing and fading to a symbol.
    I’ve browsed around the internet seeing if i could find the optimal way of doing this but no immediate succes. I’ve already tried the square 3d tutorial in after effects. Makes a square in after effects by using squares in x,y,z space rotate around a common anchor point.
    Any ideas of how i should proced? Do i need to grab hold of a 3d program? and what would be the time estimate of this?
    Michael Szalapski replied 15 years, 1 month ago 2 Members · 1 Reply
  • Michael Szalapski
    August 15, 2011 at 3:37 pm
    You can easily have video playing on the face of something that then changes to a symbol. Do that in a precomp.
    To create 3d boxes with rounded edges, make a rectangle shape in AE. Make it 3d. Duplicate it. Move it back a pixel or two in z space. Repeat that process until you have all the depth you need. You can parent all the layers for each box to a single null object for easy animation. Pro tip: unlink the scale property and play with the z-scale and watch what happens.
    If you’ve got the budget for it, Mettle’s new plugin called Shapeshifter just came out. It looks fantastic. I haven’t had time to play with it yet,
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
