Activity › Forums › Adobe After Effects › rounded corners not working on shape layer
  • rounded corners not working on shape layer
    Posted by Lars Hansen on October 12, 2014 at 9:38 pm
    I’m unable to get rounded corners on some triangle shape layers that I’ve created. In short I have three triangles that spin on their centre anchor point. I’ve highlighted the shape layer, selected the ‘add’ drop down menu and clicked on rounded corners. A new sub content item appears called ’rounded corners’ and when toggled a radius slider. When I fiddle with the radius nothing happens. The shape layers do not appear changed at all.
    Is this a glitch or am I doing something wrong?
    AE v.13
    MacPro 3,1 OS 10.9.5
    Lars Hansen replied 11 years, 11 months ago 3 Members · 5 Replies
  • John Cuevas
    October 12, 2014 at 11:45 pm
    Please post a screen grab of your timeline with the shape layer twirled open.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Lars Hansen
    October 13, 2014 at 12:57 am
    Hi Johnny, here’s the image. Shape layers 5 and 6 are duplicates of shape layer 7 but with different rotation directions and speeds.
    Thanks for your help.
  • John Cuevas
    October 13, 2014 at 12:05 pm
    I don’t see an inner radius on your triangles, wonder if that is the issue. I just made one and it works okay. Take a look at my project and see if there is a difference between the two.
    8094_triangle.aep.zip
    Thinkck.com
  • Roland R. kahlenberg
    October 13, 2014 at 12:24 pm
    You’ve set Outer Roundness to a negative value. This prevents any roundness from being applied to the shape. The lowest value allowed for said prop which allows for roundness is 0.
    BTW, only the Star Shape provides the Inner Radius and Inner Roundness properties.
    HTH
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
  • Lars Hansen
    October 13, 2014 at 2:55 pm
    Thanks guys. It worked. Another problem was that I had the shape type set to polygon instead of star.
    Cheers, Lars
