Activity Forums Maxon Cinema 4D Rounded corners in cube
  • Rounded corners in cube
    Posted by Lasse Ankanpää on June 9, 2009 at 9:20 pm
    Hi
    How to make cube to have rounded corners? I’ve searched the whole internet, but none of the tutorials worked, or i didn’t understand.
    Lasse Ankanpää replied 17 years ago 2 Members · 2 Replies
  • Brian Jones
    June 9, 2009 at 10:20 pm
    C4D Cube? Just turn on Fillet and set the radius. If you mean an editable cube select the edges and use the Bevel Selected Tool
  • Lasse Ankanpää
    June 9, 2009 at 10:57 pm
    Thanks, it worked this time. I had an object wich was set to be editable so i guess it didnt work on that… So i tried creating a new cube.
