Activity Forums Adobe After Effects rounded corners
  • Jim Scott
    April 4, 2020 at 12:25 am
    You could duplicate the Rectangle Path on the shape layer, select the shape layer and then click on Add and select “Merge Paths.” A Merge Paths 1 and Stroke 1 will be created. You can then offset the rectangles vertically by using the position controls of Rectangle Path 1 and/or 2, add roundness to one or the other to get rounded corners at the top or bottom, and use the Stroke 1 that was created to control the stroke parameters.
    14069_roundedrectangle.png.zip
    Edit: COW’s upload function seems to be having issues, so the image is not coming through.
  • Saso Goricar
    April 4, 2020 at 12:58 pm
    Thanks for this idea. I will try that.
