Activity › Forums › Apple Final Cut Pro Legacy › Round tripping from Final Cut Pro 7 to Soundtrack 2
  • Round tripping from Final Cut Pro 7 to Soundtrack 2
    Posted by Luqman Heron on September 16, 2010 at 12:50 pm
    Hi Everyone, Hope You’re all well.
    I’ve got a really technical question to throw at you about Round tripping a project from Final Cut Pro to Soundtrack Pro:
    I wanted to know whether it’s possible to send a project from Final Cut Pro 7 to Soundtrack Pro 2 as a multitrack project, make Sound changes & add instrumentals on the project, then send the project back as a master mix.
    Now here’s the big question…
    Can we then take that Master mix sequence we’ve got from Soundtrack pro that is now in Final Cut pro & then send back that sequence to Soundtrack pro and conform it with the previous one add more changes and then export a new master mix sequence??
    Basically can we continuously conform sequences as we wish??
    or is it the case that once you have conformed a sequence & sent back a master mix, this is seen as the final stage??
    Hope this makes sense.. Your help will be greatly appreciated.
    Luqman Heron.
    Luqman Heron replied 15 years, 11 months ago 3 Members · 3 Replies
