Activity › Forums › Adobe After Effects › Round layer’s corners
Posted by Filip Stillerska on October 4, 2019 at 7:11 pmHow do I round a square/rectangular layer’s corners? I would also like to have control over how much it is rounded…
Michael Szalapski replied 6 years, 10 months ago 3 Members · 4 Replies -
Greg Gesch
October 5, 2019 at 12:45 amYou can create square/rectangular Shape layers with round corners using the Rounded Rectangle Tool (use the dropdown next to the pen tool) – set the roundness in its Contents > Rectangle 1 >Rectangle Path 1 > Roundness. You can use these as Track Mattes if you need to round off the corners of other layers, images etc.
Michael Szalapski
October 8, 2019 at 12:19 pmUse the Channel Blur effect. Blur just the alpha by something like 100.
Then, apply the Levels effect. Change the Channel dropdown at the top of the Levels effect to Alpha. Crush the levels effect so that the three triangles are somewhere in the middle. Alpha Input Black to 132 and Alpha Input White to 142 – for example.
Those values will give you a very round corner on your image. The amount of blur in the Channel Blur effect will determine how rounded your edges are.– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Filip Stillerska
October 8, 2019 at 3:40 pmWow! This really worked, thank you! How did you come up with this? I didn’t know the Channel Blur effect blurred things in such a rounded fashion?!
Michael Szalapski
October 8, 2019 at 7:43 pmI don’t know how I thought about it. I guess just experience over time.
– The Great Szalam
