Activity › Forums › Maxon Cinema 4D › Round Edges
Round Edges
Posted by Scott Smith on July 22, 2014 at 11:53 amHi, How do I round the highlighted edges? I’m looking for a nice ‘fillet’ look.
Using the bevel too gives weird results.Thanks in advance,
ScottAdam Trachtenberg replied 12 years, 1 month ago 3 Members · 3 Replies -
Adam Trachtenberg
July 22, 2014 at 2:46 pmBevel tool should work. What version of Cinema are you using?
Brian Jones
July 22, 2014 at 3:17 pmif your cube was still only 1 segment for each face you can get strange results, even with Fixed Distance in the bevel tool.
Try segmenting the cube faces to get more even lines. Some pictures for a simple example, your sphere has more segmentation so maybe just 2 segments isn’t enough.
Adam Trachtenberg
July 22, 2014 at 3:35 pmI find it’s generally best to melt all of those lines before beveling, though it doesn’t seem to make much difference in this scenario. What could help is selecting the outside edge loop of the bevel and manually breaking phong shading.
