Activity Forums Adobe After Effects Expressions round counter to two decimal points while using ".toLocaleString("de-GE")"
  • round counter to two decimal points while using ".toLocaleString("de-GE")"
    Posted by Christopher Hesse on January 3, 2023 at 9:25 am
    I have a problem, which should have a simple solution, but I can’t seem to wrap my head around it.
    I’ve built a counter, using the following expression:
    beginVal =effect(“startVal,endVal”)(“point”)[0];
    endVal = (effect(“startWert,endWert”)(“point”)[1]);
    startT = effect(“startTime,endTime”)(“point”)[0];
    endT = effect(“startTime,endTime”)(“point”)[1];
    t = ease(time,startT,endT,beginVal,endVal).toLocaleString(“de-GE”);
    The counter is supposed to separate thousands with a dot, but decimals with a comma, which is why I used the “toLocaleString”-method. The problem is, that the counter is spitting out three decimals while counting, but I only want it to use two decimals.
    Does anybody have a solution?
    Chris
    Christopher Hesse replied 3 years, 8 months ago 1 Member · 1 Reply
  • Christopher Hesse
    January 3, 2023 at 1:13 pm
    At last, I did solve it myself and I realized that there were some errors in the original code I posted here, since I translated the “control for points” effect from german to english. I used point controls to circumvent the slider problem of going higher than 1 million and also to keep the effect controls to a minimum.
    Anyhow, here’s the final code:
    beginVal = effect(“Point Control”)(“Point”)[0];
    endVal = effect(“Point Control”)(“Point”)[1];
    startT = effect(“Point Control 2“)(“Point”)[0];
    endT = effect(“Point Control 2”)(“Point”)[1];
    decs = effect(“Slider Control”)(“slider”);
    t = ease(time,startT,endT,beginVal,endVal).toLocaleString(“de-DE” , {minimumFractionDigits: decs, maximumFractionDigits: decs});
    the “de-DE” stands for german formatting of numbers, but you can change that to whatever formatting you need. I’ve appended a link to stackoverflow.com where the most common ones are listed.
    https://stackoverflow.com/questions/3191664/list-of-all-locales-and-their-short-codes
