Activity Forums Adobe After Effects Roughen edges changes completely the result when changing preview resolution.
  • Roughen edges changes completely the result when changing preview resolution.
    Posted by Arne Münch on June 11, 2021 at 2:26 pm
    Did this happen to you? I recently had a 4k projekt, previewing everything in half HD most of the time.
    Then in the final render some layers that were roughen with roughen edges look completely different (a way smaller noise texture creates the effect). The effect depends from the actual resolution of the preview. I dont know any other effect with that strange behaviour.
    Do you have good ideas how to work properly with that issue?
    Arne Münch replied 5 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
