Activity › Forums › Adobe Encore DVD › rough playback
  • rough playback
    Posted by John Morrell on July 5, 2005 at 5:26 am
    I wonder if anybody can help me: I am making dvd movies which play back very well on my pc but when they are played on a dvd machine the vision is very jerky. I don’t know what I’m doing wrong.
    With thanks
    john morrell
    Tim Kurkoski replied 21 years, 3 months ago 2 Members · 3 Replies
  • Tim Kurkoski
    July 5, 2005 at 5:22 pm
    * Try different media. Try -R instead of +R or vice versa. Try a different brand of discs.
    * Keep the bitrate of your video low. Some DVD players (mostly older models) have problems reading video from burned DVDs that exceeds about 7.0 Mbps.
  • John Morrell
    July 6, 2005 at 6:28 am
    thanks for the reply. I’m using dvd -r disks and have tried a number of different brands and the bit rate is lower than 7.0 mbps, but the problem seems to be just with adobe encore. I have movie factory 3 and it does not show the same problem. I like the way encore is put together and how it produces the dvd (menues etc) and would like to keep using it if I can fix this issue.
    john
  • Tim Kurkoski
    July 6, 2005 at 5:46 pm
    How many set-top DVD players have you tried? Some players, mostly older ones, have troubles reading burned discs. You should always test your discs on as many players as possible. A good trick is to go to an electronics store and try all the models there.
