Activity › Forums › DaVinci Resolve › Rough Playback
  • Rough Playback
    Posted by Perry Trest on July 30, 2011 at 11:45 pm
    While awaiting the arrival of the full version of Resolve, I am testing with Resolve Lite.
    Using a ProRes422HQ 1920×1080 23.98fps as source, Resolve is playing back in fits.
    With no grade applied, the sound and picture start and stop abruptly during playback.
    Am I missing a playback setting?
    How do I determine if the Quadro 4000 is being utilized by Resolve?
    Thanks in advance for any trouble shooting tips.
    Perry Trest
    POSTDIGITAL, Inc.
    MacPro 8-core 2.8Ghz
    8GB RAM
    Slot 1 = GT120
    Slot 2 = Quadro 4000
    Slot 3 = DeckLink SDI
    Slot 4 = Nitris DX
    Internal 6TB 4-Drive software RAID-0
    Perry Trest replied 15 years, 2 months ago 4 Members · 5 Replies
  • Rohit Gupta
    July 31, 2011 at 2:25 am
    If you are using OSX 10.6.8, please remember to install the Q4000 driver for OSX, and also install CUDA 4.0.19/4.0.21.
    For the 2008 Mac Pro, you can set the video monitoring to 8-bit to get better playback.
    Regards,
    Rohit
  • Jake Blackstone
    July 31, 2011 at 3:04 am
    You may also see, if you can playback you prores QT file by itself. You may have a drive that is too slow or it may be to fragmented.
  • Perry Trest
    July 31, 2011 at 3:17 pm
    Ah yes, I remember reading about the 2008 MacPro requiring 8-bit playback settings. I’ll give that a shot on Monday.
    Even though playback was choppy I did a rough grade and rendered out a uncompressed 10-bit QuickTime. Both the ProRes and uncompressed QTs play back beautifully in QuickTime Player. I’m using an internal 4-drive software RAID-0 so I doubt that drive speed is an issue. The BlackMagic Speed Test redlines at around 430mb/s read/write on this RAID.
    Can you cats tell me how to verify that Resolve is indeed utilizing the Quadro 4000? It appears in the system profile, so I know the MacPro sees it.
    Perry Trest
    POSTDIGITAL, Inc.
    8GB RAM
    Slot 1 = GT120
    Slot 4 = Nitris DX
  • Spencer Tweed
    August 1, 2011 at 2:21 am
    As Rohit said, did you install the drivers?
  • Perry Trest
    August 1, 2011 at 3:26 pm
    I installed the latest drivers and switched the playback settings to 8bit and everything appears to be working well. Thank you guys for your help!
    Perry Trest
    POSTDIGITAL, Inc.
    8GB RAM
    Slot 1 = GT120
    Slot 4 = Nitris DX
