Activity Forums Avid Media Composer Rough Import from AE
  • Rough Import from AE
    Posted by Chip Hess on July 30, 2013 at 8:28 pm
    I am creating very simple animated lowers in After Effects.
    When importing into MC, I get very crunchy edges.
    Nice and clean in AE, but text looks awful in the Avid.
    AE settings are best quality, 720X486,
    RGB and Alpha. I have tried Animation codec
    and AVI, same result.
    Import settings in Avid are 601, no resizing,
    lower field first(DV rez)
    This happens once in awhile and I need
    to correct, thanks!
    Chip Hess replied 13 years, 1 month ago 3 Members · 4 Replies
  • Richard Sanchez
    July 30, 2013 at 9:15 pm
    Are your playback settings set to Yellow / Green? Or Green / Green?
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Chip Hess
    July 30, 2013 at 11:31 pm
    Which playback settings, where?
  • Pat Horridge
    July 31, 2013 at 8:29 am
    Bottom of timeline has the playback quality setting. anything less than full may give poor results. Also DV res isn’t ideal as it’s 5:1 compressed (but the alpha should be uncompressed so it should look reasonable)
  • Chip Hess
    July 31, 2013 at 2:48 pm
    Already set at best, thanks.
    I am stuck with DV at work – for now,
    and the monitor situation here
    is not the best.
    I viewed on my external NTSC monitor
    at home and it looks fine.
    I gather it is the computer monitor
    color space difference. It’s odd,
    as this has happened previously
    but does not always manifest.
