Activity Forums Adobe Illustrator Rough Edges
  • Rough Edges
    Posted by Dirk d. Lopez on June 9, 2010 at 8:44 am
    Hello I’m trying to roughen up my vector box in Illustrator but I’m not having a lot of luck with the “Distort>Roughen Effect”.
    Any tips on how to better arrive a “rough vector edge” look like on the box here:
    https://cl.ly/1KMK
    Dirk d. Lopez replied 16 years ago 2 Members · 2 Replies
  • Vincent Rosati
    June 9, 2010 at 8:24 pm
    Usually that type of thing is better done in Photoshop.
    But to do something like that In Illustrator, you could use the rectangle tool to draw a box, then apply a Brush to the stroke, from the Brush Palette.
    There are a bunch of brush libraries in the drop-down menu.
    You would probably also have to Object/Expand to match the color.
    Or, you could Live Trace an actual photo that has the rough edge that you are looking for, or perhaps a scan of your own brush strokes.
    Just a few ideas.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Dirk d. Lopez
    June 10, 2010 at 5:18 am
    Thanks a lot for the reply. I guess I just really need to dive in and work with those brushes. Im not too familiar with them. Thanks again for all the tips!
