Activity Forums Apple Final Cut Pro Legacy Rough cut edited in h264
  • Rough cut edited in h264
    Posted by Ron Shaw on June 22, 2012 at 5:52 pm
    i got a project someone did a rough cut in H264. of course it’s dropping frames. they didnot convert before editing.
    What is the safest and easiest way to convert both the rough cut and the dailies to apple prores.
    needs to be error free.
    thanks
    Ron
    Ron Shaw replied 14 years, 2 months ago 2 Members · 6 Replies
  • Shane Ross
    June 22, 2012 at 5:58 pm
    Media Manager and the RECOMPRESS option.
    Shane
    Little Frog Post
  • Ron Shaw
    June 22, 2012 at 6:43 pm
    looking at that. will it override or delete the other files?
    i donot want to delete override the files
  • Ron Shaw
    June 22, 2012 at 6:47 pm
    can i recompress to the same drive.
  • Shane Ross
    June 22, 2012 at 7:02 pm
    It won’t override anything. It will make new files with the compression you choose. And yes, you can recompress to the same drive.
    Shane
    Little Frog Post
  • Ron Shaw
    June 23, 2012 at 3:07 am
    Thanks 1 more thing, should I use the option that says duplication clips and make new project?
    Ron
  • Ron Shaw
    June 23, 2012 at 2:34 pm
    it may be used for broadcast or screening in a theather is pro res 422(hQ) overkill or should i do pro res 422
