Activity › Forums › Adobe After Effects › Rotoscoping Workflow
  • Rotoscoping Workflow
    Posted by Henner Woehler on February 1, 2008 at 11:37 am
    Hi there,
    i need to create a short film (60 secs) that should look something like this: https://www.youtube.com/watch?v=xUZFF3EFozU&feature=related
    Right now i think there’s no other way to create it than drawing every single frame by hand (maybe every second frame will do it too). My question is if you got any hints for me how to do it the most efficient way. It came to my mind that AE is not the best tool for this task..
    Maybe Photoshop CS3 with the new timeline integrated suits better?
    Should I use some cartoon or outline filters in AE to prepare the footage and make the drawing job easier (i’m not thaaat good at freehand drawing)?
    Shall i use morphing plugins and draw only a quarter of the frames?
    The footage will be well-lit green-screen material and the actors will have a lot of make up to make it easier for me to draw.
    By the way: The cartoonizer tutorial by Aharon did not really impress me (sorry dude 😉 ). Do you think it will do the job with footage like mine?
    Hope you guys can help me out!
    Henner
    Henner Woehler replied 18 years, 7 months ago 3 Members · 3 Replies
  • Steve Roberts
    February 1, 2008 at 2:48 pm
    Try aplying paint>vector paint to the footage, using onionskin mode.
    Do it every other frame, maybe by precomping the footage, applying posterize time to half the frame rate, then applying VP to the precomp.
    Morphing every few frames would be really tedious, because you have to set “from” and “to” points manually, at least in the plugins I’ve used.
  • Joe Moya
    February 2, 2008 at 4:53 am
    Your example was probably done with a lot of preparation during the original filming of the sketched characters…. and, used a good blue/green screen.
    But…the post editing to achieve this line sketch can be achieved with a photoshop IF you plan the shot right… what is “exactly right”, depends heavily upon what you want to achieve with this style of editing.
    Personally, I would use the photoshop’s color pencil artistic filter on each frame… and work the process out on a single frame until you get close (…just how close you can achieve this effect with the least amount of work, depends heavily upon how you film the original frame source). After you have done this, you would want to automate this process with PS’s Batch or Create Droplette (…which you should use depends upon how much RAM you have and much automation is need during the keystroke recording process). Finally, you would import this into a good editing software and strobe the frames to remove frames to achieve a cartoon-like motions.
    None of this process would require rotoscoping (assuming you film it correctly)… but, could require some touching up of frames (which will be signficantly easier and faster than rotoscoping).
    I may not be specific enough in this post… but, quite honestly… to provide a lot of detail would take a lot of time and would make a pretty good tutorial for those who make instructional tutorials. At least hopefully, I may have given you a direction from which to start. For details, you might do a search of the site and look for references regarding cartoon effect and/or Photoshop keystroke recording. It may take some time to research, but you will find some useful information and details about achieving the results you indicated in your example.
    Joe Moya
    BTW, you might have noticed… I made no mention of using AE to achieve this line sketch effect. The only use of AE may be in some tracking issues (and… I think it would be much easier and faster to do tracking for the sample video with Imagineer’s Mocha). Other than tracking (…if you don’t have Mocha), to achieve the sample video line sketch effect you could be better off using photoshop and a pro-level editing software.
    …….. did a quick look at a prior project…….
    …look at PS’s Filter>Sketch>Stamp … that should get you where you need to be much easier and faster than Artistic>color pencil (using a black and white picture).
    Joe
  • Henner Woehler
    February 3, 2008 at 10:39 pm
    Thank you very much so far.. i’ll have a look at the ps-filters and will do further researches!
