Activity Forums Avid Media Composer Rotoscoping Using Spectramatte in AMC5
  • Rotoscoping Using Spectramatte in AMC5
    Posted by Ronen Gur arye on May 14, 2011 at 6:57 pm
    Hello There,I am using the spectramatte fx on some green screen footage,what i am having a big headache is rotoscoping the hair on somebody head(long hair that gets thinner in the ends) – i am playing with the value inside the fx – like tolerence and erode but failing to get to a good result
    would like to know if anyone has some advice or workflow around this probleme,the
    Erik Peterson replied 15 years, 4 months ago 3 Members · 3 Replies
  • Grinner Hester
    May 15, 2011 at 3:51 pm
    maaaan, I’d not tear into trying to rotoscope hair strands. lol You may get a better key grom the BCC keyer. I often do. Outside of that, of course keylight in AE is yer buddy. I only use Avid’s keyers when pinched for time.
  • Ronen Gur arye
    May 15, 2011 at 4:06 pm
    yeha i know about doing it in AE (but strongly want to stay in avid) but bcc is a good idea i will try it,thanks.
  • Erik Peterson
    May 16, 2011 at 3:28 am
    Good Key results often take multiple keys combined to get those good results. Pull a key that keeps the nice hair detail, don’t use erode it will only hard clip your edges. Select output matte. Pull a second key for the middle area, use erode here. Select output matte. If you have something like Gen arts sapphire you can combine these using layer selecting a blend mode. Or you can use paint on top of the matte output to get a similar result. Place a matte key on top of these and now you should have a key with greater edge control. Add as many as necessary. I agree other programs make this process easier. Some keyers have this functionality built in. It’s that balance of how quickly vs how good.
    Best of Luck,
    Erik
