Activity › Forums › Adobe Photoshop › Rotoscoping in Photoshop
  • Rotoscoping in Photoshop
    Posted by Chrishanyok on October 10, 2005 at 3:58 pm
    Hello
    I’ve recently become amused with using quicktime Pro to breakdown a movie into individual frames, then opehing them up in Photoshop, creating a new action using a specific filter(like the cutout) to perform primitive rotoscoping, which I then reorganize into a mov file using quicktime. Anyway the problem that I’ve run into is that because of the diferences in terms of shades/hues/shadows/lights of the individual frames,I get a flicker effect in the images, as oppose to a solid image quality. Is there any method I could employ to reduce these flickers? Or do I have to go back in, and correct it frame by frame?
    PS: I export the movie into the image files PSD or TIFF.
    Richard Harrington replied 20 years, 12 months ago 2 Members · 1 Reply
  • Richard Harrington
    October 10, 2005 at 6:27 pm
    You can open the QuickTime directly though Image Ready
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
