Activity › Forums › Adobe After Effects › Rotoscoping in After Effects
Posted by Tony Luke on October 17, 2007 at 4:23 pmHey all –
I’m doing an art project that involves rotoscoping characters from movies into my own home videos, and I’m just wondering how effectively I can accomplish this in After Effects. I have found it to be an incredibly tedious operation, and I’m sure there’s plug-ins out there to help, but how feasible would it be to accomplish in AE and have it still look good?Any other suggestions? Thanks so much!
Bob Bonniol replied 18 years, 11 months ago 4 Members · 4 Replies -
Tony Luke
October 17, 2007 at 5:00 pmwhat? did you even read my question?
all im asking is would I be able to accomplish this seamlessly using After Effects.
Mike Clasby
October 17, 2007 at 5:54 pm1) Click on the “Sticky Posts” at the top of the main page:
COMMON AFTER EFFECTS QUESTIONS !!!!!!!!!!! PLEASE LOOK HERE FIRST by Joel Hooton on Oct 10, 2006 at 3:20:09 pm
and scroll down to:
Rotoscoping / Masking / Greenscreen2) In this post is a link to a great tut on Roto, especially how to create masks for different body parts, one for the swinging arm, one for the torso, one for a leg, etc.
https://forums.creativecow.net/readpost/2/917680
Then when you change mask shape from frame to frame, actually choose points where there is a major change, then often you can just rotate the mask for the leg or arm as it swings (double click the mask to get a transform box like in PhotoShop). The tut is for combustion but the principals are the same for AE.
3) If you can use track points to track an object, this script will attach a mask to trackpoints, more useful for nonhuman regular shapes.
https://forums.creativecow.net/readpost/2/916507
4) There is also the painting method to paint out the background, go to the Cow AE Tutorials Page (the link is down for me at this moment) and search with your web browser for “roto” and “paint”.
5) Anyway you do it it’s tedious stuff, and you can see why greenscreening was invented.
Jimmy Brunger
October 18, 2007 at 10:27 amYou can accomplish most roto needs in After Effects with enough time, but if you want really good mattes with variable feathering then AE is not great as you can only soften the whole mask at a time, either in X axis or Y or both.
Combustion has b-splines with variable feathering per point in the mask, or there’s programs like Avid’s now deceased Elastic Reality – which has b-splines which you may be able to pick up cheap these days.
For cheap plugins for AE to make your life easier/give you better results try PF Feather by Re:Vision, or Roto by Silouette FX. Or for really powerful integrated tracking/roto apps that will speed things up considerably look at Imagineer Systems Mocha or Motor. They are quite a bit more money though. They’re the best you can get though. Depends how often you’re going to be doing this…
*Production Studio Premium CS2 / *Combustion 3 / Mocha v1
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5 monitors / Sony BVM-20G1E / DVS SDI Clipstation / Wacom Intuos 3 A4 / 110GB boot/80GB media/600GB RAID-0 -
Bob Bonniol
October 28, 2007 at 10:10 pmMaku,
You have to admit you answered rather tartly… Remember, these forums are here to dispense help and knowledge.
On to your methodology. Frame by frame rotoscopy is prone to problematic mask jitter, even with advanced variable Matte softening techniques, none of which are inherent in AE.
Actually there ARE short cuts, and they benefit the art of rotoscopy in general, by allowing the user to define critical positional points in footage, and allowing the intervening frames to be mathematically calculated and tweened by the plug or app. As already described below, Roto from Silhouette FX and Motor/Mocha are both great solutions for this.
Realistically you still have to go back and revisit every 7th or 8th frame some times, in kinetic shots, but it really reduces jitter, and achieves great smooth solid mattes.
I’ve used Motor (when it was Alpha version) and it’s big brother Mokey to Rotoscope vast amounts of old Sinatra footage for the Live in London show mounted 2 years ago. Motor literally allowed that production to happen on time and on budget. We also used Silhouette on that show with great results.
SO know there are better ways… Finding true, zen infused roto Artistes these days is getting tough.
-Bob Bonniol
MODE Studios
http://www.modestudios.com
Contributing Editor, Entertainment Design Magazine
Art of the Edit Forum Leader
Live & Stage Event Forum Leader
HD Forum Leader
