Activity Forums Adobe After Effects rotoscoping flikering.
  • rotoscoping flikering.
    Posted by Benito Sanz on April 9, 2005 at 6:39 pm
    hi people, i have a series of images, about 70, imported from photoshop as a sequence, i cleaned the backgrounds in photoshop, i knew it wasn’t going to be perfect but i find vector paint quite painful to do the job. the point is that the backgrounds are not perfect and it flikers a bit, it’s only about 1 or 2 pixels, can anyone tell me how to remove that please.
    thank you very much.
    Paul Carlin replied 21 years, 5 months ago 3 Members · 4 Replies
  • Chris Smith
    April 9, 2005 at 10:19 pm
    Personally I use masks since you let AE interpolate the shapes so there is no flickering. Using Paint to me is like taking on the limitations of the Hand Rotorers of Yore, flickering and all. Not to mention time consuming to actually do every frame.
    My only suggestion is to undo the area that is flickering and do that part using masks. Of course use standard roto technique of setting a key at the begining and end of the clips, then go to the middle of the clip and adjust the mask, set key, split those keyframes, adjust mask, set key, etc… till it tracks with the object enough.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Benito Sanz
    April 10, 2005 at 8:50 am
    thanks chris i wil give a try, the only thing is that i don’t find the pen tool in after effects very accurate as the one in photoshop, may be is just cos it animates.
    thanks for your advice.
  • Chris Smith
    April 10, 2005 at 2:52 pm
    If you have the rotobezier option unchecked, it should be identical to PS as it uses bezier curves. I personally prefer rotoing with rotobezier on since it uses B-Splines instead of bezier.
    Chris Smith
  • Paul Carlin
    April 11, 2005 at 12:39 am
    You can enable and disable rotobezier by right-clicking the mask.
    As far as accuracy, you can go full screen and zoom in to what you are working on. Don’t forget that the space-bar (Hand) and Z (zoom) keys can be held down temporarily while you are creating a mask.
