Activity Forums Adobe After Effects Rotoscoping a Chair Spinning
  • Rotoscoping a Chair Spinning
    Posted by Daniel Elder on July 13, 2006 at 6:50 pm
    I have someone sitting in a chair spinning 360 degrees with a locked down shot. The chair has these speakers attached to them, I need to animate sound bars coming off of the speakers. Since it is a locked down shot the spin happens in an eliptical fashion, how would I attach these sound bars to move in an eliptical 3D space and have them move to the smae motion as the two speakers? Thanks in advance
    Daniel Elder
    Associate Producer
    http://www.luminair.com
    Daniel Elder replied 20 years, 1 month ago 9,510 Members · 2 Replies
  • Daniel Elder
    July 14, 2006 at 2:00 pm
    Sure did, thanks for the response. I have been toying with the idea of using motion tracker…didn’t work so well. Now I am working with the null
    object and parenting to the null objects. Thanks again. Will keep you posted.
    DE
    Daniel Elder
    Associate Producer
  • Daniel Elder
    July 17, 2006 at 5:40 pm
    I will give this a try, for now what I did which was quite laborious was, I animated everything to Null #1 and then adjusted the keyframing, it looks pretty good, but I will have to try your method in the future. Thanks again.
    Daniel
    Daniel Elder
    Associate Producer
