Activity Forums Adobe After Effects Rotoscoping
  • Joe Moya
    March 20, 2010 at 8:57 pm
    If you are tryinig to rotoscope the entire lady in the picture… then, you will need a LOT of time, patience and LUCK.
    You will have to make a choice between saving the hair or dropping the background out. If it was me… I would sacrifice the hair… as for the blur, that is a BIG problem and there is no simple solution (… if any solution)… specially when you look at the foreground plants in the video.
    If there is any way to reshoot… then, that would definately be the best option. If not, then prepare for a LOOONG and painful rotoscoping project…. and, in the end… I doubt it will look good.
  • Curious Turtle
    March 22, 2010 at 6:44 am
    Joe is right, you’d better settle in for a long roto session.
    There are some things you can do for the hair, and if you’re lucky it will get rid of some of the foliage. Try to build up some procedural mattes first, to limit the amount of stuff you’ll have to roto. It’s still not going to be a simple task. It will probably help you keep in more hair detail.
    Here’s a link to take you through the process.
    If you are doing this sort of roto, I would highly recommend using Mocha or Mocha AE & mochaShape to take some of the pain out of it. The big boy version of mocha lets you deal a lot better with the motion blur. I go through lots of techniques in my paint & roto course Cut and Shut.
    Good luck in your project. Some good quality coffee will make the whole thing a better experience!
    Ben
    Curious Turtle Pro Video
    Training | Editing | Support
    Out Now – Creative Color Grading with Apple Color, Film Wash Color Effects Vol. 3
    & Mocha training for AE & FCP
  • Conrad Olson
    March 22, 2010 at 4:03 pm
    You don’t need luck and it will certainly be posible to rotoscope the person sucessfully. It might not be easy but it is defintely possible.
    It well take some time to do it properly. Just don’t let the negative post above put you off.
    If Hollywood decided to reshoot everything that might be a little bit tricky to rotoscope then they would never get a movie finished.
