Activity Forums Adobe After Effects Rotoscoped stills & Parallax Effect…
  • Rotoscoped stills & Parallax Effect…
    Posted by Andrew Akada on August 22, 2013 at 7:16 pm
    I’m looking to expand on rotoscoped stills I’m using as source material (e.g. abandoned cars and debris) but the edited footage I’m working from has a series of reverse shots filmed from a different angle.
    To overcome this I was hoping to avoid any problems with parallax by using hulks that had been photographed from multiple angle. But recently I came across an interesting technique I saw employed in a documentary series.
    Here are the links:
    https://www.youtube.com/watch?v=N0WKPrgf9sY (MOSCOW)
    https://www.youtube.com/watch?v=JwxOZNpaJAY&list=PLnNmfyY_ccRHl0yAJZy3r5Nfq2-Xr22di&index=2 (KIEV)
    The effect I’m aiming for can be earmarked at 42:47 on the time code for the “Battle of Moscow” video and at 26:26 for the “Kiev” video. All of these elements were pulled from still photographs of the period without any access to alternate angles or takes and I was curious how one might go about replicating this effect in a program such as AE.
    Can this be done using the 3D tracker or something else? I just need a little direction to get my studies moving in the right direction…
    Andrew Akada replied 13 years ago 3 Members · 3 Replies
  • Todd Kopriva
    August 23, 2013 at 2:01 am
    Vanishing Point Exchange:
    https://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c1103906c6dea-7f29a.html#WS149A6D84-9FC5-4d93-BCFD-FF841F659454a
    After Effects team blog
  • Jeff Kay
    August 27, 2013 at 4:19 pm
    To elaborate. VPE maps a still image onto planes. This creates 3D planes in AE with the still image mapped onto it. Its easiest to see the effect (also by far the easiest to create) for something simple like the corner of a room, or a hallway, something with very obvious perspective. However it doesn’t distinguish between objects or anything in the still image. For instance for a room corner, if there is a chair in the room, then the VPE will map the chair as if it were flat to the wall.
    For the effect seen, you would create the VPE, clonestamp/remove any objects that are not meant to be part of the plane, cut out those objects in the original still, and import/place them into the AE composition. The setup of these are by far the biggest part. Once the 3D environment is set up, then its really just camera movement.
  • Andrew Akada
    September 5, 2013 at 4:39 am
    Thanks for the input! But I made a mistake on the time stamps for the videos. It should be 42:47 for the KIEV video and 26:26 on the MOSCOW video.
    I’m not sure if this changes your perspective on this but I appreciate the feedback nonetheless!
