Activity Forums Adobe After Effects rotoscoped dancers, which app is best?
  • rotoscoped dancers, which app is best?
    Posted by Dave Scruton on October 14, 2008 at 3:04 am
    I would like to make animated silhouettes of dancers,
    such as you might remember from the old whited-out
    ipod ads. (without hiring people and green-screening)
    What’s the best place to start? Is Poser sufficient to
    create dancing figures? Do I need Maya?
    Any suggs?
    Thanks loads
    can you pls cc any thread replies to fractal@maui.net???
    dave scruton
    fractallonomy
    http://www.frak.com
    Ronny Berglund replied 17 years, 11 months ago 3 Members · 2 Replies
  • Joe Moya
    October 14, 2008 at 4:23 am
    Without using a green screen background to key the footage… you certainly are making your project harder than you should.
    But… if you must go the rotoscoping direction. The best software to use may be Imagineer’s Mocha (full version…not the AE plug-in version)… but, a lot depends upon how you shoot the footage… if you plan it right you might be able to do the rotoscoping with AE or a less expensive rotoscoping software.
    No matter the choice of software you use to help you with your rotoscoping… rotoscoping is going to be more time consuming and difficult than using a properly set up green/blue screen as the method to achieve the results you are looking for.
    In fact, depending upon the character’s movements, rotoscoping may be too difficult to achieve silhouettes that are useable… for example, rotoscoping leg movements can be very difficult and hair can be almost impossible to rotoscope.
    Bottom line, rotoscoping dancing people (specially with leg movements and hair included in the frames) will be a VERY difficult process even for a very experienced rotoscoping specialist. I would seriously rethink the idea of not using a green/blue screen keying process.
    Joe Moya
  • Ronny Berglund
    October 14, 2008 at 6:42 am
    If you have sufficient skill in modeling and animation i guess it’s probably possible to make a model (or use a poser model) and animate it dancing and then render it in all black or however you need it rendered..
    It’s probably going to be time consuming to get it to look natural though and if you don’t have experience in animation/modeling/rendering it’s probably faster (not to mention easier) to just find a dancer and a greenscreen..
    //Ronny
