Activity › Forums › Adobe After Effects › RotoBrushed Matte Dissapears
  • RotoBrushed Matte Dissapears
    Posted by Harrison Gruber on January 8, 2014 at 12:27 am
    Hey All,
    Trying to teach myself some after effects for a simple plate compositing task and I’m running into what
    looks like a basic no brainer kind of problem but I cannot crack it.
    I have my footage. I had it highlighted in the timeline and it was in my layer window. I created the mask. But then when I scrub through the clip to check the rotobrush mask at second 1 frame 12 it dissapears. I don’t have any keyframes and there are other color correction filters that are still there. I have tried re-doing it ten times and without fail the mask goes away at some point. I’m missing some really obvious piece of this puzzle, what am I doing wrong????
    Roland R. kahlenberg replied 12 years, 8 months ago 3 Members · 4 Replies
  • Todd Kopriva
    January 8, 2014 at 2:09 am
    Dave is correct.
    Specifically, regarding your Roto Brush issue, you have moved to a time that is outside of the Roto Brush span. Read the Roto Brush documentation for details about that.
    After Effects team blog
  • Todd Kopriva
    January 8, 2014 at 2:11 am
    Start here for Roto Brush help:
    https://blogs.adobe.com/aftereffects/2010/04/roto-brush-in-after-effects-cs.html
    … but heed Dave’s suggested link, too,
  • Harrison Gruber
    January 8, 2014 at 4:34 am
    So this documentation talks about moving through the clip manually but would I be doing that in the layers panel or the timeline?
  • Roland R. kahlenberg
    January 8, 2014 at 3:16 pm
    The Rotobrush Tool is active for use only in the Layer Panel. Of course the results of the Rotobrush Tool affect the Comp Panel content.
    You may also want to view this tutorial – https://provideocoalition.com/cmg_keyframes/story/after-effects-apprentice-free-video-adjusting-propagation-settings
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
