Activity › Forums › Adobe After Effects › rotobrush 2 help
  • rotobrush 2 help
    Posted by Irv Levine on March 5, 2021 at 3:32 pm
    i was wondering if someone can help. i’m trying to use the new rotobrush2 tool and having a few problems. i’m trying to use it for a not- real- well- lit green screen. i’ve watched and read numerous tutorials and i think i’m doing things mostly right. one problem though is i don’t have the 2nd bar below the first bar at the bottom of the image. also, when i hit the space bar it will propagate for about 20 frames then stop and the effect disappears from the remainder of the shot. Also when i initially start up the effect it tells me to change the frame right to 59.54. i switched it and had the same problem. i’m sure i’m doing something wrong. i feel like i’m so close to using this incredible tool.
    Irv Levine replied 5 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
