Activity › Forums › Adobe After Effects › Rotobezier shortcut
Rotobezier shortcut
Posted by Chris Petridis on January 11, 2013 at 1:18 amHi Guys,
I’m just wondering if there’s a way to make a shortcut to toggle on and off rotobezier using a keyboard or mouse button.
Chris
Roland R. kahlenberg replied 13 years, 8 months ago 3 Members · 6 Replies -
January 11, 2013 at 1:27 amALT+W selects the Roto Brush tool. Like other tools, the short cut either delves into the tool’s variation with no toggle available. Instead, you either click on another tool or hit the short cut key for another tool.
BTW, you can use the 1 and 2 keys on the main keyboard to move back and forward repectively – this is much more useful that the PAge Up/Page Down keys which is situated towards the left of the keyboard.
HTH
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7) -
Chris Petridis
January 11, 2013 at 7:29 amHi Roland,
Thanks for that answer but I’m actually talking about the rotobezier within the pen tool, pressing G just changes it to a feather.
C
January 11, 2013 at 11:08 am[Chris Petridis] “Thanks for that answer but I’m actually talking about the rotobezier within the pen tool, pressing G just changes it to a feather.”
LOL!!! My speed reading skills suck! Sorry about that.
There is no shortcut key to select or toggle the rotobezier feature.
Cheers
Sam Freeman
January 11, 2013 at 12:45 pmFrom memory you used to be able to cycle through all the bezier tools using the ‘G’ key, but they changed that in CS6. I can’t imagine why they did it (unless they wanted to draw attention to the new variable feather tool) – as it really slows me down not having the shortcut. Is there a way to map your own shortcuts to alter this?
Maybe Todd will know more?
Cheers
Sam -
Sam Freeman
January 11, 2013 at 12:59 pmAha – I’ve found it. If you go to your preferences>General there is a tick box that says ‘Pen shortcut toggles between Pen and Mask Feather tools’. Untick this and your ‘G’ key will toggle through all the pen tools.
January 11, 2013 at 5:04 pmBUT it won’t access the Rotobezier feature unless Rotobezier was switched on in a prior routine.
Cheers
