Activity Forums Adobe After Effects roto scoping/ roto brush
  • roto scoping/ roto brush
    Posted by Dawud Ali on February 2, 2011 at 10:56 pm
    hi guys
    thanks for your time,
    this may be a simple question but can the new roto brush CS5 be used to created a mask so the effect can be copied and pasted over solid layer to i.e see a figure dancing instead of the actual person
    main: i want to use the rota data from one layer1 as a reference for a second layer2. if that makes sense
    layer1: clip of a 3d model spinning on the spot
    layer2: (a solid layer) will be set to a blend mode and scroll top to bottom of model
    Dawud Ali replied 15 years, 7 months ago 3 Members · 3 Replies
  • Olin Padilla
    February 2, 2011 at 11:06 pm
    I don’t have cs5 yet, so I don’t know if there is a direct way to do it,
    but you can always use your roto-brushed layer as a track matte.
  • Todd Kopriva
    February 3, 2011 at 6:13 am
    Yes, using the layer on which you’ve applied the Roto Brush effect as a track matte is a good way to accomplish this.
    By the way, I strongly urge you to read the documentation and watch the tutorials regarding Roto Brush before jumping in. It is not a beginner tool to be used with learning about it first; it may be one of the trickiest features in After Effects.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Dawud Ali
    February 4, 2011 at 2:43 am
    thanks All,
    i used the roto brush same time i applied a track matte, i wanted to expand the outlines of the rota brush but couldn’t do it so i just duplicated the layer blurred it and added a glow (like a glowing outline for the 3dmodel)
