Roto Rumble – Stuff Looks ok inside the comp, faulty outside
I have a comp with some quick motion. I rotoed an element. Everything looks clean.
When I go to the higher level comps I suddenly artifacts along the border of the element,
as if it is not masked properly (which it is, of course).here is an example:
you can also notice there is a slight shift in the motion in the frame, even though its the exact position on the timeline. Obviously this can drive a man insane.
• fps: 23.98 in all comps
• no time-remapping / effects. I thought it was time remap related but not.anyone had this happen to him ?
cheers
Billet<== BilletHQ | Creative that Goes to 11 ==>
https://www.billethq.com
