Activity Forums Adobe After Effects Roto Brush will not render correctly because of framerate
  • Roto Brush will not render correctly because of framerate
    Posted by Iris Moleman on July 6, 2014 at 10:11 pm
    I opened an AE-file I hadn’t used for a while, and I got te following warning message:
    ‘Roto Brush & Refine Edge will not render correctly because te source frame rate changed from 23,999 fps to 24,000 fps. To fix, change it back.’
    I changed the framerate of the footage-layer (via ‘interpet footage’), but the Roto Brush still doesn’t render the right way.
    I don’t understand why the framerate and Roto Brush are wrong, because I didnt’ever change the framerate.
    Maybe it went wrong when the project was converted to the new AE CC – 2014 format?
    I hope someone can help me out,
    thanks in advance.
    Iris Moleman replied 12 years, 1 month ago 2 Members · 8 Replies
  • 8 Replies
  • Michael Szalapski
    July 7, 2014 at 3:30 pm
    Check your comp frame rate too (just in case).
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Iris Moleman
    July 7, 2014 at 9:04 pm
    Yes, I already checked the comp framerate, but it was set to the right framerate.
    I opened the project in AE CC 12.2 and that worked well. I checked ‘interpret footage’ and it says the framerate of the footage is 23,999 fps. But when I open the same footage in AE CC 2014, the framerate is 24, for the same footage.
  • Michael Szalapski
    July 8, 2014 at 1:11 pm
    That’s odd. What kind of footage is it? Format? Codec? Etc.
    – The Great Szalam
  • Iris Moleman
    July 8, 2014 at 2:47 pm
    It’s an .mp4 file, 960 x 540, 24 fps
  • Michael Szalapski
    July 8, 2014 at 2:57 pm
    Where did this non-standard mp4 originate? Like, from where did you get it?
    Also, what happens if you import the CC version of the project file into a brand-new CC 2104 project?
    – The Great Szalam
  • Iris Moleman
    July 9, 2014 at 3:52 pm
    [Michael Szalapski] “Also, what happens if you import the CC version of the project file into a brand-new CC 2104 project?”
    The same warning message shows up. And the framerate is still 24 fps, the same as when I open it as a project.
    [Michael Szalapski] “Where did this non-standard mp4 originate? Like, from where did you get it?”
    I downloaded it from vimeo: https://vimeo.com/78448851
  • Michael Szalapski
    July 9, 2014 at 5:04 pm
    Try transcoding the problematic footage into a proper production codec.
    – The Great Szalam
  • Iris Moleman
    July 9, 2014 at 7:53 pm
    Okay, I’ll try that. Thank you!
