Activity Forums Adobe After Effects Roto brush tool question??!
  • Roto brush tool question??!
    Posted by Ben Hartley on November 4, 2011 at 12:39 pm
    Hello,
    I am cutting out a background image from behind a sitting figure by using the roto brush tool.
    When I apply the brush it applies to 20 frames or so and then disappears/unattaches. Even though the figure is barely moving.
    ANY SUGGESTIONS would be much appreciated.
    SEE IMAGE.
    If it looks good, look at it.
    Ben Hartley replied 14 years, 9 months ago 2 Members · 2 Replies
  • Michael Szalapski
    November 4, 2011 at 2:16 pm
    Go through the resources linked here: [link] As you’ve discovered, the Roto Brush tool is not as intuitive as you might think. The linked resources should help you work much more efficiently with the Roto Brush.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Ben Hartley
    November 8, 2011 at 11:18 am
    Thanks alot for that.
    However can anyone shed any light on why the tool marks only stick for 10-20 frames and then disappears??! (I have the comp set to the same frame rate and it is viewed in Full resolution)
    I REALLY need to solve this problem asap, any help is appreciated.
    SEE IMAGE – I need to cut the guy out from the background, so the logo is not longer there.
    THANKS
