Activity Forums Adobe After Effects Roto brush Propagating
  • Roto brush Propagating
    Posted by Sean Franklin on May 5, 2014 at 5:07 am
    I’m finding it very difficult to use the rotobrush in CC because everytime I stop and try to fix an issue with the edge it begins to progagate ever frame that was already done. If you make adjustments doesn’t it have to redo this anyway? Why can’t you stop it from doing this so you can make changes without it freezing the computer?
    Thanks for any help!
    -Tim
    http://www.TimSFranklin.com
    Michael Szalapski replied 12 years, 3 months ago 2 Members · 1 Reply
  • Michael Szalapski
    May 15, 2014 at 4:17 pm
    I’m not sure I understand your issue. However, I can tell you that the Roto Brush is not as intuitive as it looks. I highly recommend going through some resources on it. Start here: https://blogs.adobe.com/toddkopriva/2010/04/roto-brush-in-after-effects-cs.html
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
